Looked through everything to locate the wing root farings and eventualy had a look in the finishing kit parts list where I found them. Had to upack the whole box just about as they were taped to the bottom. Decided to have a bit of a sort out and try to make a bit more room, which I did. Fitted and drilled the wing root fairings in place on both sides.
Wing root faring covers the gap between the wing and the fuselage
