Brief Description: Fuselage final assembly - forward fuselage belly s
Began fuselage final assembly as follows:
1. Prepped and primed underside of forward fuselage frame and bottom skin.
2. Riveted UAT antenna reinforcing plate to bottom skin. Attached antenna using stainless hardware and Dow Corning 738 non-corrosive, electrical sealant.
3. Cleco'd bottom skin in place and riveted per Rans rivet schedule, except for use of CCPQ-43 rivets next to the nose gear mount weldments and AAPQ-43's for the next four rows aft.
4. Cleco'd floor channels to center spar. Riveted bottom skin to center section.
