Brief Description: LH wing final assembly - bottom skin riveting
Riveted bottom skin on LH wing per Rans construction manual as follows:
1. Riveted inspection hole frames per Rans rivet schedule. The round holes have nutplates installed so that covers can be held with 6-32 machine screws instead of rivets.
2. Riveted a small reinforcement plate and plug previously fabricated to hold Dynon OAT probe. This assembly is fitted into the slot made for the factory pitot tube.
3. Riveted bottom skin, starting from the center of the main spar, working in a fan pattern.
4. Tip rib not riveted to allow for wing tip fitting.
