Brief Description: LH wing final assembly - lower aft skin
Began finall assembly of the lower aft skin on the LH wing as follows:
1. Installed fuel sender, fuel pickup, fuel quick drain, and fuel fent into tank and pressure tested. Installed tank assembly into tank bay.
2. Prepped and primed tank torque angle and tank bay skin. Riveted together per Rans instrctructions.
3. Prepped and primed lower aft skin, skin stiffeners, inspection hole frames, and wing hinges. Cleco'd into place on wing frame. Cleco'd tank bay skin in place.
