Drilled the 3 L angles for each side. For the short L angle, I'll have 3 holes in the side skin but only one from the seat pan..tight space, but its support only so it will be doing its job.
UPDATED NOTE: So I got ahead of myself here...thought the 3 L angles on each side were the normal L angle...NOT...there is actually a part...C75F11-4, that are oversized L angles that need to go here and also you need to ensure that on the long one you avoid drilling where it ends up on the edge of the Landing Gear Weldment and/or on one of those flange supports. By luck I avoided the flange supports but not the edges. I had to remake the parts using C75F11-4 (6 of them provided) and going in the holes I had already made...there is one hole near the edge on each side, where I'll countersink that particular rivet into the skin...there's always a solution to the boneheaded moves!!!
Did more powder coating of small steel parts....think I did about 10 individual parts
