I am basically looking through the manual and seeing what areas have not been completed and signed off. I wanted to get the rudder access covers off the shelf and into the plane along with the step floor cover over the fuel on/off valve. The rudder access covers were a little difficult to reach in and screw in place, but luckily the weather was assume this morning and the garage was quite comfortable (low 70s vs. mid 90s). I also did a trial fit on the fuel cap, but still need to drill the vent holes. I’m holding off until I confirm with Vans if that is still needed since the tank has a separate vent.
