Michaels Web Site
Date:  6-25-2010
Number of Hours:  1.00
Brief Description:  FINISHED RIGHT WING SPAR!
Finished the right wing spar!
Tightened and torqued the last 8 bolts holding W11-01 and put torque seal on all torqued nuts.
Then went over the whole spar cleaning up any dings or scratches from the construction process.
I do have 8 rivets that I'm not fully happy with that I will go back and drill out a bit later, and replace. But I need to do some practice, first. Up to now I've only drilled out pulled rivets.
Total time for spar assembly (I had already made the parts some time ago) was 35 hours, including making the spacing jigs.
