Michaels Web Site
Sonex Standard Gear
L01/L05
Wheels & brakes
- Packed the wheel bearings and installed the wheels, brakes, retaining nut and cotter pins. Sheet L01 is now complete.
- Located, drilled for, and secured the block for the brake cables. On a tail dragger it gets mounted to the engine mount (photo #2).
- With the engine mount and block temporarily in place I marked the firewall for the holes for the brake cables.
- Removed the engine mount and used a cobalt drill at low speed to drill the holes (photo #3).
Wheel bearings greased, and wheels/brakes installed.
Block for brake cables, secured to the engine mount.
Two, 1/8" holes for the brake cables to exit, going to the block in photo #2.
RV-7 Home
Sonex Standard Gear Home
2445
Aluminum Materials
45
Angle Parts
63
126
132
Bending Brake
85
Cowl
84
99
179
233
Finish-Polish
66
85
FLIGHT!
382
Hardware
95
Learning Point
111
Smoke System
Upholstery
638
