Michaels Web Site
Sonex Standard Gear
L01
Tap axle for bolt
The ends of the two axles have to be tapped for bolts that will later hold the wheel pants in place.
I had to borrow a good tap from a friend. My Harbor Freight one was not tough enough to bite into the steel of the axles.
It took 1 hour for each axle! Lots of slow going and lots of cutting fluid. The last thing you ever want to do is break a tap off in the hole!
10-32 tap in the end of each axle
RV-7 Home
Sonex Standard Gear Home
2445
Aluminum Materials
45
Angle Parts
63
126
132
Bending Brake
85
Cowl
84
99
179
233
Finish-Polish
66
85
FLIGHT!
382
Hardware
95
Learning Point
111
Smoke System
Upholstery
638
