Brief Description: Elevator bell crank and mounting.
Finally time to finish the F728 Bell crank mounting. Removed the channel and finished drilling as needed. Riveted the support angle to the channel. Assembled and riveted the F635 bell crank assembly together and fabricated the spacers as needed. Test fit it into the mounting assembly then remove and stored for installation later. Finish riveting the F728 into place.
