Placed the leading edge onto the spar and cleco'd in place. Rieted the aft rib flanges to the spar. I was able to reach them all except for the center rib. I will complete that one once the top skin is installed and the wing moved to the work bench. Them, there will be easy access through the hstall warning access hole. Next, installed all LE skin the spar flush rivets.
