Took some time off for flying. Did 2 "dual instruction' cross countries, and my first "Solo" crosscountry. Good weather is hard to come by this time of year, so i have to take advantage.
Continued with wing prep and assembly: Re-installed the skeleton into the wing stand and carefully leveled, strainghtend, and checked for twist before beginning assembly. Installed the completed "leading edge" and fully riveted in place. Next, installed the R. Fuel tank and bolted the baffle plate mounts in place. Everything lined up perfectly!
