Brief Description: Made templates for Cowl Bottom heat shields
Removed the clamps holding the Cowl Duct Seal to the duct interface. The seals are well attached except at some of the corners.
Made paper templates for the heat shield and taped to the inside of the Cowl Bottom. Installed the cowl to the fuselage and noted the locations fo the parts that will be hot (exhaust pipes, muffler). Marked the parts of the templates that needed to be trimmed. Removed the Cowl Bottom and marked the perimeters where the heat shield will be located.
