Brief Description: More work on the cooling duct and interface
Removed the clecoes holding the Cowl Duct Interface to the Cooling Duct and the latter to the Cowl Bottom. Drilled two #30 drain holes in the Cooling Duct. Sanded the areas on the interface, Cooling Duct and Cowl Bottom that will be bonded together with epoxy flox and fiberglas layup.
