Brief Description: Trimmed Drain Hose and Vent Tube, checked SV
Reviewed several sections to look for steps that I haven't done.
46-14: Turned the Dynon Skyview on to see if it recognizes the Rotax 456180 Oil Pressure Sensor. Spent a lot of time pressing the buttons and rebooting but I didn't see the sensor listed. I'm not sure if I'm looking in the right place or there is something wrong. The connections looked right. Will check again later or wait until I get the SV Touch Upgrade.
46-18: Trimmed the F-01225 Drain Hose approximately 1 inch below the bottom of the Gascolator.
49-06: Trimmed the FF-1218 Oil Tank Vent Tube so there will be more space between the bottom tip and the Cowl Bottom.
45A-06: Installed/tightened the cushion clamps holding the FWF Wiring Harnesses.
Tightened several zip ties that I intentionally placed loosely before.
