Brief Description: Work on EGT, FWF and Power wiring
Connected the WH-00063 Rotax Fwall Fwd Wiring Harness to the AV-50000A Control Module. Installed a housing to the EGT d-Sub connector (for the EGT Wiring Harness) and connected it to theSV-EMS-220 Engine Monitoring Module. Installed the WH-00062 Power Wiring Harness to the back of the AV-50001 Power and Switch Module. Routed the wires from the harnesses through the firewall penetration. I cut a plastic tubing to make the FF-1216 Pitot Line per the plans but this was probably not necessary since the AFT Pitot Line is long and it can just go through the firewall penetration. Since I did not complete the D-180 installation, the pitot line modification is probably not necessary. It gets confusing when the updated plans instruct a modification step but you did not complete the steps in the original (obsolete) plans.
