Brief Description: Put coolant in engine, work on Canopy Fairing
49-06 and -07, PAP G4-1, Rotax Maintenance Manual: Verified the radiator and coolant hoses were properly connected and then put 1.8 L of Coolanol radiator fluid. It was not enough to reach the neck of the Expansion Tank. Will get more coolant and add to get the level up to the neck of the tank (per the Manual).
34-16: Sanded the cured UV Smooth Prime and the microballoon resin on the Canopy Fairing. It seems the Smooth Prime has lumps even after several minutes of mixing. When the lumps are sanded they leave small holes. I might try using a microballon mixture for the pin holes.
