Started work on the main wheel fairings. Sanded the inside of the U-00001A Front Fairings to removed the high spots of fiberglass.Trimmed the wheel openings to the scribe lines. Trimmed the Front Fairing aft edge so the holes in the U-00002 Wheel Fairing Brackets will line up with the dimples in the aft fairing. Decided to drill #30 holes in the dimples and clecoed the fairing brackets and measured how much to trim from the aft edge of the front fairing. After getting a good fit I taped the 2 pieces together and match-drilled #40 the dimples in the front fairing into the aft fairing. Did only one main wheel fairing at this time.
Primed the U-00006A-1 Nose wheel fairing brackets and the U-00006B Splice Strips and U-00006D Doubler Plates.
