50-07: Loosened the CT-00100 Outer Set Screw on the left choke cable so it can pivot fully when it is pulled or pushed. Squeezed the trailing edge of the top panel of the rudder and checked for "flatness" using a straight edge. Also squeezed or "thumped" the trailing edged of the left flaperon to flatten the bulging or fix the scooping, as appropriate. Installed the Tailcone Fairing.
