Brief Description: Worked on SB, installed cover plates and carpet
SB 16-08-01 Stabilator Bearing Inspection: Performed this SB and did the "Swing Inspection" which was OK. Did Step2 and "thumped" the outboard ribs of the Stabilator. No movement was detected. The aircraft complies with this SB.
50-06: Checked the throttle cable connections and movement and they are OK.
35-06: Installed the F-1276B Cover Plates to the bottom of the Fuselage.
Installed (temporarily) the following carpet pieces: RV12F1, RV12F2, RV12F3 and RV12B2.They look nice. Will install the Velcro tapes on the fuselage for final installation later.
