Brief Description: Prepped Canopy Catch parts, did Nose Fork SB
34-25: Deburred the F-1231G Canopy Catch and then primed it. After the primer was dry I sprayed a clear acrylic ename. Removed the 3 rivets fromt the Roll Bar Frame. Will install the Canopy Catch after the paint is dry.
SB 16-05-23: Re-inspected the Nose Fork for cracks and none was found.
Removed the remaining protective cover from the bottom of the Fuselage and cleaned the dried adhesive and ink marks form the bottom fuselage and the bottom inboard wings.
Installed a new filter and digital regulator on the air compressor. The old regulator was stuck at a low PSI and could not be adjusted.
