Brief Description: Cleaned Canopy, Placard and Systems check
Removed the plastic protective cover from the top of the Canopy. There was a lot of adhesive residue on the Canopy and most of it was removed with Plexus cleaner. There are some stubborn spots that will need to be cleaned later.
42M-03: Installed the Fuse Holder on the Map Box door.
51A-02: Installed another N-Number placard on the right instrument panel to cover the holes where the FC 403 Intercom was.
33-02: Cleaned the Fuselage and temporarily placed the F-1227 Seat Ramp Cover and F-1214 Step Floor Cover. 33-04: Installed the seats.
PAP G1-1: Did more system checks. The Stall Warner now sounds "normal" on the headset. PAP G3-1: Retested the fit and security of the seat belts and harnesses and they're OK. PAP G9-1: Rechecked the placards and fuse holder installation.
