My RV-12 Build Log
RV-12
Finishing
9-3-2016
PAP, 31, 42D
Secured wires, installed Fuse Side Covers
PAP G1-1: Retested the radio and it is still working properly.
31B-07: Reconnected the Aux Music Molex plugs and connected an Ipod playing music. The music sounds very good and without distortion.
31-10: Tightened the nuts holding the headset jacks.
31B-24: Vacuumed the fuselage and installed the F-00032 Fuselage Side Covers.
31B-25, 42D-20: Secured the wires above the Panel Base and in the Tunnel with lacing tape and tie wraps.
Removed the bottom spark plugs from the engine and to drain oil from the cylinders.
R Fuse Side Cover installed
Wires & Harnesses secured
Tunnel wires secured
RV-12 Home
2532
236
88
Finishing
288
838
189
372
Inspection
Modifications
189
Pre-Flight Checks
276
