Brief Description: Installed gasket at wing root. Worked on radio.
PAP G1-1: Checked the radio and the same problem persists. Disconnected the Aux Music jack and it did not solve the audio problem. Changes in the Config and Setup modes did not help either.
33-05: Placed a rubber gasket (U channel) at the wing root to seal the gap between the wing and the fuselage. This will be temporary since the plane is unpainted. After painting I can place the foam seal from Van's that is glued to the side of the fuselage. Had to trim the gasket at and near the wing spar to clear the rivet heads.
