Brief Description: Covered avionics bay, fixed Fuse Pin Stoppers
29-05: Cleaned the area above the Panel Base. Removed the dried epoxy on the F-1240 Upper Forward Fuselage Skn and then secured it to the Fuselage and Instrument Panels.
30-02: The F-1217C Fuselage Pin Stoppers are sticking and hard to move even after I applied oil. Disassembled the Fuselage Pin Assemblies and filed the small tube where the stoppers go into. Also sanded the Stoppers. Cleaned and oiled the parts of the assembly and then put them together. The Assembly now works better and the stoppers spring back (upward) when the "trigger" is released. Did some cleaning of the hangar
