Brief Description: Installed ELT Bracket, did hangar clean up.
Installed the F-1205G ELT Bracket on the F-1205A Mid Fuse Brace and then connected the Coax cable to the ELT antennna.
Cleaned the F-1240 Upper Fwd Fuselage Skin of dried adhesive. There are areas with cured epoxy that will need treatment with a stripper. Spent time cleaning the hangar, putting hardware in bins and organizing tools.
