30-02: Reassembled the Fuselage Pin Assemblies. Somehow, once the screws are tightened the pin stoppers do not spring back. Not sure if the threadlocker leaks around the stoppers.
N16-07-14: Replaced the Passenger Warning Placard to the current version (F-1200 PW). Installed a 12 inch “12” sticker on the left side of the V-Stab. There were a lot of air pockets under the stickers which I tried to clear by pricking small holes in them. I was about to install another “12” sticker on the right side but it was too big. Because of the slant the corner angles extend beyond the forward and aft edges of the stabilizer. Decided to remove the sticker from the left side and just leave it bare at this time.
Did more clean-up of the sticky film under the Tailcone and the leading edge of the left Flaperon. Used liberal amounts of Goof Off and acetone to remove the adhesive.
Retested the Com radio and it is still the same. Took photos of the configuration and will send to Garmin.
