Continued with cleaning the Canopy with Plexus spray. With a lot of Plexus, rubbing with cotton cloth and a plastic scraper I was able to remove the dried epoxy and the pieces of electrical tape that were stuck between the Canopy and the Fairing. Redrilled the #30 holes in the aft of the Canopy Fairing that been covered with UV Smooth Prime and microballoons. Installed the screws (3 on each side) that were removed for the fiberglass layup of the Fairing. Cleaned the adhesive residue from the Canopy Skirts.
Removed a few more blue vinyl cover from the top of each wing and cleaned the surface with acetone and, where needed, Goof Off.
