Brief Description: Work on interior, Canopy Fairing and COM
33-02 and -03: Installed the F-1214 Step Floor Cover and F-1230 tunnel cover so I can trial fit the carpeting. I have the optional map pocket which has to be screwed onto the Tunnel Cover and Step Floor Cover. It will be hard to find the holes once the carpet is in place. I just may not install the map pocket. Anyway, a fire extinguisher can be place on the top of the Tunnel Cover.
34-15: Sanded the Canopy Fairing again with very fine sand paper. It should be ready for a coat of white epoxy.
PAP G1-1: Turned the radio On and, again, the audio problem is back. It was working yesterday but is acting up again. I’ll have to get professional help now. I did go to the Setup and Config modes again and made adjustments but no improvement.
Had Data Plate engraved with required information.
