Got a suitable clear plastic hose from Lowe's which fit the gascolator outlet fitting. After charging the battery I turned the Master Switch ON, opened the fuel shut off valve and started my stop watch. One gallon was in the bucket after 140 seconds. Fuel flow is satisfactory and meets specifications. Reconnected the fuel line to the gascolator outlet. Applied Loctite 567 to the fitting threads.
34-15: Did some more sanding of the Canopy Fairing and then applied UV Smooth Prime.
