Brief Description: Fuel system check, Canopy Fairing work
PAP G4-1: Put 4 gallons of premium auto gas in the fuel tank. It was hard to remove the fuel tank cap and had to use a small screw driver to pry it open. Turned the Master Switch ON and check for leaks at the fuel line connections and I did not see any. Sampled the gascolator and the initial flow was a little cloudy white. Disconnected the Gascolator to Fuel Pump Hose to test fuel flow rate but the plastic tubes/hoses I got would not slide over the gascolator fitting. I'll have to get a larger hose from Lowe's.
34-15: Did some more sanding of the Canopy Fairing and got rid of most of the rough spots. A little more sanding and I can put another coating of UV Smooth Prime.
