Brief Description: Looking for source of short circuit
I'm still working on finding the short in my wiring. Disonnected Pin 9 (Strobe Pwer) form the harness that connects to the Power and Switch Module and then re-connected the harness and the battery. With Pin 9 disconnected theNav/Strobe fuse does not blow. This still does not pinpoint where the short is but it could be in the Control Module or somewhere in the Optional Harness. Rechecked the wiring at the sides of the Fuselages and they seem correct. Peeled off the heat shrink around the noise filter to see if the corrections are right and they are. Checked the wiring in the wings again and tested the Nav/Strobe lights with a 12 volt battery. The Nav lights work in both wings. The Strobe lights up in the right Wing but not in the left. I'm not sure if the strobe will work in the left wing when the wings (Strobe Sync wire) are connected to the Fuselage.
