PAP G1-1: Reconnected the harnesses to the AV-50000A Control Module and then connected the battery. The AP Disconnect switch light is on when the Avionics Switch is turned ON. When I turned the Nav/Strobe switch ON the fuse again blew and the AP Disconnect switch light is out. With the Avionics switch in the OFF position, the blown fuse indicator light is on with the Strobe switch in the ON position but not with the Nav switch ON. When the Nav switch is ON the AP Disconnect switch light turns on.
31B-04: I tested the Trim wire Pins (#31 and #32 in the Fuselage d-sub connector) with a 12 volt battery and did not see movement of the AST. Pin 1 in the Switches receptacle in the Control Module continues to show continuity as long as the Options d-sub connector is connected to the Control Module.
Removed more blue vinyl film from the top of the Fuselage and under the Wings.
