Brief Description: Checked movement of controls and attachments
PAP G2-1: Checked the stabilator attachments/connections and position with control stick movement. All control movements are correct. Checked the rudder attachments.
PAP G2-2: Checked the Flap Handle movement and locking mechanism - works well.
11-07 (Rev 3): Checked the Servo Tray and noted the castellated nut was not yet safetied. Replaced the cotter pin with a new one and safetied. I noticed that one of the pitch trim servo wire pins is pulled out from the ES-00044 Molex Plug. It would not lock in place when I re-inserted it. Pulled the pin hooks outward a little bit and this allowed it to lock in place.
