PAP-G1: Put brake fluid again in the brake system and moved the pedals back and forth to get rid of air bubbles. After a couple of tries I didn’t see air bubbles. There was a very slight leak between the F-1289D-R Caliper Brake Line and the U-1203 Inboard Main Gear Attach Brackets. Tightened the fitting. So far, I didn’t see leaks anywhere.
Section 34: Sanded the inside lower part of the Canopy that is behind the Canopy Fairing. After cleaning with denatured alcohol I sprayed with gray primer to cover the part that is visible through the Canopy.
