Placed the Rudder Pedal Rigging Stop on the pedals per the plans and clamped the F-1258 Rudder Cable links to the rudder horns. Marked the cable links where holes will be drilled. Removed the links and then connected the F-1239 Rudder Cable to the WD-1205 Rudder Horns. Used a drill press to drill holes in the links. Trimmed the links per the plans and deburred the edges. Connected the links to the horns of the WD-1206 Rudder Pedals. The movement of the Rudder looks OK when the pedals are depressed.
