Notification 14-05-22: Fabricated the C-1214 Latch Block, match-drilled #30 holes, countersunk the left most hole and then riveted the block to the F-1231F-1 Latch Plate. Bolted the WH-W1115 Canopy Latch Switch Ground Wire to the F-1232A Roll Bar Brace. Crimped a spade connector to the WH-00109 wire.
25-03: Primed the forward edge of theTailcone bottom (F-1282) and side (F-1280) skins. This is the surface that will be placed between the aft skins of the Fuselage.
I had given the F-00083 Baggage Floor to a friend who want it installed while the fuel tank of his RV-12 SLSA was removed for maintenance. He brought me a replacement which I dimpled, deburred and primed.
