Brief Description: Work on Wing electrical connector & Fuel vent line
31A-09 and 40-11: Removed the primer around a tooling hole in the outboard seat rib. Bolted the right terminal of the ES-00103 Noise Filter to the hole for grounding. It was not easy because of the tight space. Thanks to the various tools I had gotten from Harbor Freight which were extremely helpful. Placed a few more zip ties to secure the wires going to the electrical connectors and OAT probe. Installed the ES-00077 Floating 8 Pos Connector Female and ES-00078 Floating 8 Pos Connector Male to the left and right F-00034 Wing Electrical Brackets, respectively. Drilled a 1/4 hole in the left F-0032 Fuselage Side Cover for the AOA tube. Inserted a snap bushing in the hole and passed the Tygon tubing. Installed the Fuse Side Covers on both sides.
37-08: Temporarily installed the fuel tank to see the fit of the fuel vent lines. The T-01219C Fuel Vent Line measurements and bends appear right but the flared end is lower than the nipple of the fitting by about 1/2 inch. Redid the bend in the upper part of the vent line and slightly increased the forward bend in the lower part of the line. This did the trick and the fit is good. Removed the lines and the fuel tank. Will do the final install later.
