Trimmed the inboard wing skins to have a minimum gap of 1/8 inch between the wing and the fuselage. Used a combination of shears, files, expanding drum sander and Scotchbrite. Had to remove a lot from the bottom skin because of the land gear SB and the addition of a doubler/stiffener at the sides of the fuselage.
Worked on wooden sawhorses which I'll use to support the Tailcone before attaching it to the fuselage. The pre-made sawhorses from the stores are too high to use, even at their lowest settings. Assembled a roller stand and roller seat from Harbor Freight.
