Brief Description: Completed service bulletins for fuel tank
Cleaned (vacuumed) the inside of the fuel tank. Applied more sealant over the shop heads of the rivets securing the T-00008 and T-00009 Tank Clips. Installed the T-1209 Res Sender Plate after applying sealant between the plate and the tank. Installed a lock washer under the head of one screw. Checked continuity between the ground plate and the F-1205 Fwd Tank Bracket and it passed.
Except for testing the fuel tank for leaks and installing it in the Fuselage, SB-11-12-14, SB-13-12-19 and Section 37B are complete.
