Drilled two holes inthe F-1282-R Skin for the Fuel Vent Air Line and T-01219B Fuel Vent Line. Enlarged the holes per the plans.INstalled a SD-42 BSLF rivet for the air line and removed the shank using a pin punch.
Located and collected the various parts I'll need to do the leak test for the fuel tank. The T-406A Fuel Cap had a sticky O-ring. I'll see if it will work. Otherwise, I may need to replace it. I think I'll test for leaks by submerging the tank in soapy water. This was recommended by some in the VAF forum and it has the advantage of being quicker than other methods.
