Brief Description: Work on Fuel Tank mods and Cowl Hinges
37B-03: Drilled a 1/2 inch hole into the F-1207C-R Baggage Bulkhead for the Fuel Tank Vent Line. Drilled out 2 rivets from the F-1207J Attach Angle and the right Baggage Bulkhead. This is part of the fuel tank vent mod and the F-01296 Vent Bracket will be riveted to this place.
38-03: Beveled the eyelets of the F-1201J and F-1201K Upper Cowl Hinges per the pans. This was time consuming work even with the use of a rotary tool cutter and small expanding drum sander.
38-04: Fabircated the F-12116B-Left and -Right Side Hinges and marked the hole locations. Also marked the hole locations on the F-12115 Side Hinges, the remaining halves of the F-1201K and F-1201J Upper Cowl Hinges, and the F-12117 Lower Cowl Hinges.
