Brief Description: Work on Cowl, Hinge Pins and Fuel Tank parts
Did some more trimming and filing of the edges of the Top Cowl. Trimmed (by grinding) off the ends of Hinge Pins. Shaped the ends of the Top, Lower and Mid Cowl Hinge Pins per the plans. Deburred the F-12115 Side Hinges.
Deburred the edges of the T-00008 Inboard Clip and T-00009 Outboard Clip (new Fuel Tank Mod parts). Also deburred the edges of the Trim Tab which I'll install later in the build.
