Brief Description: Made 2 Hinge Pins and prepped Fuel Tank for mods
38-03: Made the other F-12117 Lower Cowl Hinge Pin and F-12116 Mid Cowl Hinge Pin and ground the ends.
37A-03: Placed the template over top left of the Fuel Tank and center punched the hole for the mechanical fuel gauge and the screw hole.
37B-03: Placed the template for the Fuel Tank Vent Modification to the rear of the Tank and center punched the hole for the vent. There are currently 3 modifications for the Fuel Tank and I'll do them later after I open the tank and have time to do all three. The mods require the use of fuel tank sealant which has a short life once the components are mixed.
