53-11: Bent the F-00050 Wire Routing Bracket per the plans. Installed the Flap/Pushord Assembly and the Wire Routing Bracket, and secured the F-1262 Flap Handle Blocks to the (F-1215) Inboard Seat Ribs.
32-05: Re-measured the Control Stick Pushrod Assemblies and made adjustments. Connected the assemblies to the WD-1212 Control Sticks and the inboard ends to the F-1263 Flaperon Mixer Bellcranks. Had a hard time placing and keeping the 5702-75-60 washers between the outboard of the bearings and the slots at the bottom end of the control sticks. I eventually crazy glued the washers to the bearings which helped but I still had to slightly widen the slots at the bottom of the Control Sticks where the bearings insert.
