25-05 – Clecoed the right F-1277 Turtle Deck Skin and then clecoed the F-1277A Aft Window to the Turtle Deck Skin. Match-drilled holes through the forward part of the Aft Window into the Roll Bar. Removed the window and final drilled the holes to #27.
34-06 – Taped the right C-1202 Canopy Skirt to the Canopy and Fuselage and match-drilled holes into the Canopy Frame. Deburred the holes in both Canopy Skirts and dimpled the 5 most forward holes in the skirts. Countersunk the 5 most forward holes in the Canopy Frame that will match with the dimpled holes in the skirts. Removed the Canopy from the frame.
