Brief Description: Tapped holes in Roll Bar and filed the Canopy
25-05 – Final-drilled #36 and tapped 6-32 the holes in the Roll Bar. Removed the Turtle Deck Skins. Will install the Aft Window after I connect the Tailcone to the Fuselage and install the fuel tank. 34-06 – Filed the Canopy edges very close to the marks I had placed previously. Decided not to use the rotary cutter to avoid the risk of damage to the Canopy. However, the process was quite slow.
