Brief Description: Canopy and Instrument Panel work
Attached the F-00031 Skyview Update Panel, F-00023 SV Center Inst Panl and F-1202U Right Inst Panel to the F-202D Panel Attach Strips so the F-1240 Upper Fwd Fuse Skin will assume its “final” shape and I can check the fit of the Canopy Frame. The fit is good except for the forward bow of the frame is greater than 7/16. I bent it forward a little bit. Decided to stop work on the Canopy Frame because I was not sure where exactly to place the C-122 Align Blocks and what position they should be in. Will check the Homebuilt Help video and see how they did it. Did some shop work and organized hardware – labeled and put them in parts bins. Assembled a small work table for the drill press.
