Brief Description: Installed main wheels, nose gear and anti-rotation
35-04: Installed the main landing gear wheels and brakes. I still have to get and install the washers to be placed between the axle nuts and the main wheels.
35-06: Separated the U-1210C Anti-Rotation Plates and deburred and primed them.
35-07: Tightened the bolts attaching the Nose Gear Assembly to the bottom of the fuselage and torqued them to 38 in.lbs. Added the prevailing torque of the nutplates which is 16 in lbs to 22 in lbs for the bolts, for a total of 38 in lbs. Countersunk the rivet holes in the Nose Fork Assembly for the Anti-Rotation Plates. Deburred the Nose Fork Assembly and riveted the Anit-Rotation Plates to it.
