Brief Description: Bolted main gear axles, installed nose gear
SB-12-11-09: Final-torqued the bolts securing the main landing gear legs to the Center Section Assembly and applied torque seal.
35-04: Bolted the main gear axles to the main landing gear legs and torqued to 100 in.lbs. per the Matco Manual. I couldn't find the washers to be placed between the axle nuts and the wheels (bearings). I'm not sure if I misplaced them or did not get them with the kit. I will need to order and install them before lowering the wheels to the floor.
37-07: Bolted the WD-1201 Nose Gear Assembly to the fuselage but did not final-torque the bolts.
